It is currently Sat Mar 23, 2019 5:16 pm
 Post subject: Help! Have NOS Paso tank that needs filler cap and flange Et
PostPosted: Tue Oct 09, 2018 3:39 pm
Hi Folks,
I have a 1988 Paso 750 which had a leaky tank, that was one pinhole too many...so I found a NOS tank in so.cal. mint inside, still had foil covers over the ports with red overspray, neat to find a relic like this. Anyway, my existing tanks gas cap, flange and fuel tap do not fit this tank!! The new tank has a bigger hole with a different screw count and the gas tap is a female 20mm hole on the opposite side from where my old one had a male threaded fitting!!??? What year and model Paso tank do I have? Paint looks right, cagiva elephant in Ducati logo (my old tank had no elephant...)
Will attach some pics with measurements shortly...
 Post subject: Re: Help! Have NOS Paso tank that needs filler cap and flang
PostPosted: Tue Nov 06, 2018 6:56 pm
Looks like the tanks is from a 907 i.e. so now looking for the gas cap and flange+gasket for this thing, any help would be terrific! Thanks folks...
Chris
PostPosted: Tue Nov 06, 2018 11:54 pm
you can most likely still find one at your local Ducati dealer. Same on used on the 851
If not try Ed Miltch at Guzzitech he recently took in a 907
PostPosted: Wed Nov 07, 2018 6:28 pm
I have a new one in at my shop for a P750 tank purchased from
https://www.ebay.com/str/valtermotousa/
I also have spare SS M6 countersunk allen head machine screws.
Hit me up if Ed Milch can't do ya. Best of Luck!
Pictures please!
PostPosted: Thu Nov 08, 2018 8:54 am
That seller has an interesting NOS 'P750' tank. It's a 907IE tank with a P750 paintjob. It has the connections on the right and the brackets for the fuel pump and tubes. Since the P750 was out of production when the 907IE came out I wonder why Ducati did this. :wacko:
PostPosted: Thu Nov 15, 2018 5:52 pm
Hi Folks,
Thanks for the assist...and sorry about my slow responses, work and home life a bit hectic...
Best,
Chris
