Front Brake Light Switch
I've been running down a few electrical gremlins on my bike and yesterday I realized that I don't have any brakelight when I use the front brake. Is the switch mounted at the hand lever? I've been through the manual and it's not clear. Could someone take a pic of how it's mounted? My perches look stock but I dont see how the switch would mount.
1988 Red Ducati Paso 750
1999 BMW R1100S
1999 BMW R1100S
Re: Front Brake Light Switch
follow the brake line from the pump to the splitter at the lower triple clamp. There`s a pressure switch.
Check TAV.18 of the parts caatlogue.
- Brutus
- year: 1989
I've recently replaced the stock brakelines at the front with stainless steel lines. Just two lines from the pump to the calipers. Still have to add a micro switch on the ps13 pump lever instead of the pressure switch.
Léon
Léon
Bevel Heaven has either of the lever mounted switch required when you loose the junction block and pressure switch with braided lines
According to Ducati the stock switch has been discontinued. There's a local auto parts store in my area that caters to guys who do a lot with European imports. I took the old switch to them and he pulled a generic one from the shelf. The difference is it had the tapered pipe thread. He ran a 10mm x 1.0 die down the threads, cleaned it up and it works perfectly. Total cost; $22.50.
1999 BMW R1100S
1999 BMW R1100S
- whitepaso
Try here. I believe the one needed is a few up from the bottom of the page.
http://www.mgcycle.com/index.php?cPath= ... 0f5503f3fc
