Dellorto Carbs?
Posted: Thu Sep 02, 2004 3:08 pm
by Chilly_bill
Anyone know where I can find info on the conversion from the Weber carb to the Dellorto carb for My Paso?
Anyone know where I can find the Dellorto carb itself?
Is there much difference between the two?
Posted: Fri Sep 03, 2004 9:05 pm
by mike
I am going to have a complete Dell'orto conversion setup available for sale in the next few months...
Posted: Sat Sep 04, 2004 2:15 pm
by mika750paso
There is a complete dellorto kit available in Malossi catalogue,
go to this site
http://www.malossi.com
Mika
Weber vs Dell'Orto
Posted: Fri Sep 17, 2004 10:26 am
by Frankie
Hi, I kept the original Weber but placing the suggested pressure regulator between pump and carburetor.
I used a typical second-hand Alfa Romeo Giulia fuel filter (glass) with pressure regulation bolt on top (found for free!).
The result is incredible!!
No more fuel leakages, no more engine stops!!!
Very responsive throttle etc.
The typical problems of this bike desappeared.
You all have to try it before spend big amount of money to replace carburetors!!
Frankie
Posted: Fri Sep 17, 2004 6:53 pm
by Christian
Hi Franki,
Could you explain with more detail what are you exactly doing in the inlet weber ?
You decrease the pressure or increase the pressure at the inlet carburettor ?
Thanks you
Christian
