New owner to a Paso 750
Re: New owner to a Paso 750
With the swingarm halfrings from STARTWIN and a longer chain you could restore the full range for chain tensioning.
thanks G., indeed I forgot this additional option
- Meat_Biscuit
Hello Gentlemen,
Any tips on what type and weight engine oil I should put into my Paso?
Thanks!
Thanks!
Marshall
American Veteran - I am the 0.45%
- Skins
20/50 synthetic is recommended in the manual, if I remember correctly, but that was written quite a while ago, and I think there have been significant developments in lubrication technology since then. I have 5/50 synthetic in mine at the moment.
0/40 in both of mine
- Meat_Biscuit
Thanks for the input! Another issue I'm having is finding wheel bearings. Not that I'm having issues finding wheel bearings, but finding them for a good price. I got the part # from the shop manual and parts catalog (found on this forum! You guys are the best ) which is 75163.2054 and the gentleman at Florida Powersports (my hometown Ducati experts) have quoted me $45.99 USD for each one. I went directly to the SKF website, and they want the same price. Does anyone know of another manufacturer of these bearings? Thanks again for the input on the engine oil!
Marshall
SKF, FAG, INA, Timken, NSK, NKE etc. There are many.
Here in Germany you can find them online for €12 while the actual list price is 35. That`s B2B price hence you have to know someone with a business to be able to order. There must be many more sources in the US.
I`m sure there`s someone who knows an online shop where they can be found for affordable prices.Front and rear wheel bearing (2x per wheel)
id 20mm od 42mm width 16mm
SKF 63004-2RS1 / C3 or
FAG 63004-2RS or
RIV 30 L 20
- Meat_Biscuit
Hey guys,
Got the tank resealed and fired up the engine! It runs good, fired up after just a second. But now, coming from the area about the clutch plates, when I have the Paso in neutral and I let go of the clutch, it sounds like there is a high pitched squealing noise when its idling. Any suggestions on what this might be?
Also, as the pic might say differently, I have my garage all cleaned out and will be putting new seals in the forks here very soon. One little step at a time. But, the main thing, is that she starts and idles pretty
Marshall
- fredskidoo
That would be your "throwout" bearing as I like to call it. It is the piston that the fluid clutch pushes against the clutch plates to disengage - generally the head of this piston or "button" as its been called has been worn to the point where a new bearing and a machined button will need to be installed. This is what you will find when you remove your clutch cover; the worn piston/bearing/button assembly and it's contact point.
Here is what I've had made - Including a skateboard wheel bearing pressed into the original piston and the button also pressed into the center race of the bearing. You are looking at 2 units, front and back, respectively before being pressed into the piston.
It took me quite a lot of effort to no longer call my Paso sqweeky-ass clutch "Flipper" i.e. Dolphin chatter
BTW - cost was machine shop minimum 1 hour (not really actually it was only $20 - w/much love), cost of 2 skateboard bearings ($8) and my existing piston.
'87 750 Paso 751412
Ethan is right although usually the noise would appear when the clutch is disengaged, hence the piston assembly pressed against the pressure plate but you write the noise is when you let go of the clutch.when I have the Paso in neutral and I let go of the clutch, it sounds like there is a high pitched squealing noise when its idling.
In that case you may have another problem. As the bike was stored for such a long time you should remove the throw out piston, clean it and the cylinder in the clutch cover and replace the o-ring.
It may be that the rubber started sticking to the cylinder walls and the piston doesn`t move far enough back to completely lose contact to the pressure plate.
