Anyone have one they'd like to sell? Found a crack on the left side one on our Paso. (called "U Bolt" on the microfiche).
Here is the strange part. Microfiche shows both sides having the same part number. But they are clearly different. A minor difference, you can see how one side has a machined groove, that is in mirror opposite on the other clamp.
Anyone think the machined groove matters?
Axle clamps?
Axle clamps?
- year: 1989
Re: Axle clamps?
PM sent
Re: Axle clamps?
yes, the groove matters. The swingarm has the same and the excenter sits in it.
Re: Axle clamps?
Right, that's why I'm wondering why Ducati shows the same part number, 037040225, for both sides? Puzzling. Unless the replacement ones have a groove on each side.paso750 wrote:yes, the groove matters. The swingarm has the same and the excenter sits in it.
Was just wondering if anyone knew.
Speedmade, thanks for the help! PM replied.
- ducapaso
Re: Axle clamps?
If ducati spare parts microfiche shows the same # there must be some mistake. I think you can only look at advices for scraped and dismantled pasos and send a PM to ask fot what you need. Anyhow you can make it machined in Avional or similar alu materials even fi it will not look like the OEM one
ex...Red "smooth" 753349
Re: Axle clamps?
Either there is a mistake in the parts numbering OR the parts are only available as a pair ????
Re: Axle clamps?
Hmmm, this is the only possibility that makes sense. Good call, sir! (Sold as pair makes sense)Mc tool wrote:Either there is a mistake in the parts numbering OR the parts are only available as a pair ????
