Clutch cover
Clutch cover
Did this in about 45 minutes....
Had to put it here to show how proud I am!!!!
- (174.67 KiB) Downloaded 1052 times
- ducinthebay
Re: Clutch cover
That should let that rattly clutch noise out a bit. Oh, and the dust too.
Phil
Phil
Re: Clutch cover
I thought about doing that too but as the thrust from the slave piston is centred in the middle of that inner ring of holes you drilled and being only ally I decided against it , ( did you get 1/2 way round before you thought of that too ? ) . How did you get on with sorting the functional issues you had with the clutch ?
Re: Clutch cover
the clutch cover has ribs all inside it that make up for most of the strength, and its really thin between those ribs, so i wasn't too worried about it.
as for my clutch problem....i removed the non factory master that was on it and ordered a paso clutch master. there was a lot of gunk in the old one and when i took it apart there was leaves and trash....so, i got the correct master on the way. thanks for asking!! should fix the issue right up! then be back on the road as soon as the new sprocket retainers show up.
- randtcastell
Re: Clutch cover
It's a great feeling to imagine something that is well designed and unique for one of our motorcycles and to then execute that action or design, then sit back and enjoy the outcome from a functional and aesthetic personal point of view. I have cut away much alloy and drilled many holes and chopped off plenty of plastic and steel while adding one-off custom bits and bobs to my Bonneville much to my distraction and to the displeasure of those less inclined. I am happy for you. We must enjoy ourselves!
1987 Ducati P750
1973 Honda CB450
2022 KTM RC390
1973 Honda CB450
2022 KTM RC390
Re: Clutch cover
Hamish, you can do a lot more on the clutch cover w/o weaking its structure. These are mine.
But it`s always sad to modify a perfectly good clutch cover as these are becoming rarer and more expensive by the day.
- DSCF0442.JPG (107.88 KiB) Viewed 7717 times
Re: Clutch cover
of course things can be overdone, then it`ll break and you`ll have to improvise (found on the internet a while ago)
- bitburg_1_10062000-005.jpg (50.62 KiB) Viewed 7717 times
Re: Clutch cover
Aw crap ! that's the last thing I needed to see, I got enough on my plate at the moment with out that trying to que jump the list of things to be done , wouldn't end there either ,if I could see the clutch Id need to make it a whole lot prettier too Mmmmmmmm
Re: Clutch cover
just so you can see how they look on the inside and what they often cost:
http://www.ebay.com/itm/Ducati-Paso-F1- ... 3f260b9d13
- $T2eC16FHJGIFF.jpg (69.42 KiB) Viewed 6934 times
- Brutus
- year: 1989
Re: Clutch cover
what kind a frame is this..?paso750 wrote:of course things can be overdone, then it`ll break and you`ll have to improvise (found on the internet a while ago)
Re: Clutch cover
Bimota DB1
- Brutus
- year: 1989
Re: Clutch cover
tx. Got it..paso750 wrote:Bimota DB1
