First:
I've eliminated the Paso's stock electric fuel pump in favor of a Mikuni vacuum unit. However ... I'm not sure what to do with the remaining leads that are left dangling. More on that in a minute.
Second:
I've got no spark. I don't know if it's related to the lack of the fuel pump or what.
Now, I screwed up by taking stuff apart, not writing down what I did, and then leaving it for a couple months. So, naturally, I've forgotten what's what exactly ... but my conundrum is this: with the stock fuel pump deleted, I have a male and a female spade connector just sitting there, connected to nothing. They can't/shouldn't be connected together unless you like to blow fuses.
So, I wonder if in deleting the stock pump, I have an open ground (or something) that is killing off my spark.
Here's what's what:
- Fuel pump
- Black wire: ground, which I believe terminates in a hoop connector behind that is pinned to the frame under the brackets that hold the coils
- Blk/wht wire: ???
- Remaining connectors:
- Black wire w/ male spade connector, comes out from under the steering head/tank knob
- Grn/blk wire w/ female spade connector, comes out of multi-prong plug mounted to frame (left side) just above the stock fuel pump bracket
Questions:
- What is connected to the hoop connector pinched between the coil brackets and the frame?
- Could the pump-delete be related to my lack of spark? I doubt it, but had to ask. I even hooked the pump back up (with nothing attached to it - just to close the gaps in the wiring) to see if that would help. And it doesn't. So I'm pretty sure the pump-delete is not related to my spark issue.
- What do I do with the left-over connectors from the pump-delete? Anything? (Mikuni swappers, I'm looking at you!)
- Since the pump-delete is most likely not related to my missing spark ... now what? Everything else looks good. The bike ran (poorly, but not from lack of spark) last time I rode it. Or perhaps ... it was the beginning of the end? So, how do I tell?
