Anyone know what that small screw is for?
Looks like there's oil leaking from there.
The prev. owner had some rubbery epoxy over it which came loose.
Oil leak
Oil leak
- (128.13 KiB) Downloaded 226 times
- Brutus
- year: 1989
Re: Oil leak
I've got the same issue.. Also like to know what they do.
Re: Oil leak
Brutus wrote:I've got the same issue.. Also like to know what they do.
Is it coming out enough to dribble towards the exhaust header?
Re: Oil leak
Brutus wrote:Yes, it dribbles.
Alright. Same here.
- Brutus
- year: 1989
Re: Oil leak
plasmid wrote:Brutus wrote:Yes, it dribbles.
Alright. Same here.
Got a picture of it in the past:
- Foto0143_33.jpg (216.17 KiB) Viewed 5658 times
- ducinthebay
Re: Oil leak
I always assumed it was the oil line feeding the head and cams. I assumed it was a cross drilled hole, and that was simply a plug. I have a spare head on the bench. I'll dare to take the screw out and see what's inside. There is some Loctite that seals and holds, but I don't know the part number off the top of my head.
- streetsurfer
Re: Oil leak
Yes, a sealed oil gallery. I was advised not to try and remove them. Too soft. Sealed mine with rtv after a very thorough cleaning and it hasn't leaked.
- Derek
- year: 1994
Re: Oil leak
As stated above it's a blanking plug for an oilway drilling. They are on all the 2V engines and nearly all of them leak sooner or later. Use a thread sealant to keep the oil in.
Re: Oil leak
ducinthebay wrote:I always assumed it was the oil line feeding the head and cams. I assumed it was a cross drilled hole, and that was simply a plug. I have a spare head on the bench. I'll dare to take the screw out and see what's inside. There is some Loctite that seals and holds, but I don't know the part number off the top of my head.
as streetsurfer mentioned, locktite rtv I guess.
Thanks for the suggestions.
