Hello all,
I need to replace my rear valve stem as it is broken. Do the Oscam wheels use a special size, or can I use any standard size replacement?
Tubeless valve stems
Re: Tubeless valve stems
many of the standard sizes available might fit
- Derek
- year: 1994
They come in 8.3mm and 11.3mm sizes to fit the hole in the rim. For a Ducati you need the smaller 8.3mm size. Like these -
http://www.ebay.co.uk/itm/2-Black-Ariet ... 3ccd4575e3
Great news, thank you for helping me out. Those were actually the ones I was wanting to get.
The right angle ones look real good but I found they fouled the front calipers if you have them at 90 deg
- year: 1989
I was told by the tyre shop that the right angled ones didn't fit as they weren't long enough for our rims
So, for a few dollars, I bought a brass right-angled adaptor valve-extension to screw on when checking tyre pressures. He had some on the counter. I keep it under the seat. Works mint.
Lane
89 Dark Blue 906 Paso
- Derek
- year: 1994
Havers! I have them on my bike, they work perfectly well and they don't foul anything. I also had them on my previous 900SS and the ST4s came with them from new. The SS had the same wheels with the 30/34 calipers and the ST had the 65mm version of these calipers.Mc tool wrote:The right angle ones look real good but I found they fouled the front calipers if you have them at 90 deg
I can't of course speak for bikes with 16" wheels and/or 2-piston F08 calipers
Well, back to square one... I'll just get the straight ones then, but the right angle ones would sure make checking and adding air a lot easier.Mc tool wrote:The right angle ones look real good but I found they fouled the front calipers if you have them at 90 deg
Which is what we are talking aboutDerek wrote:I can't of course speak for bikes with 16" wheels and/or 2-piston F08 calipersMc tool wrote:The right angle ones look real good but I found they fouled the front calipers if you have them at 90 deg
I found these to be a perfect match to the original by a company called K&L and sold through The Motorcycle Superstore. They seem to be good quality, too.
http://www.motorcycle-superstore.com/36 ... valve-stem
