It is currently Sat Feb 16, 2019 1:22 pm
[ 3 posts ] |
Author |
acconboy
Post subject: Chain Tension Posted: Mon Sep 13, 2004 3:12 am |
All,
After having to adjust chain tension daily, I decided to replace with a brand new 520 roller chain. I am still having to retention it one a day. Anyone else seen this? any ideas?
Alan
Top |
jcslocum
Post subject: Posted: Tue Sep 14, 2004 2:06 am |
paso grand pooh-bah |
Don't overtighten it and inspect the sprockets for wear.
Jon
Top |
jfiore
Post subject: Chain Adjustment Posted: Wed Sep 15, 2004 4:43 pm |
Joined: Wed Jul 21, 2004 12:00 am Posts: 67 Location: Windsor, CT USA
Maybe your chain adjusters are slipping. Check the tightness of the clamp bolts.
Also, after your next adjustment, try making a reference mark on the eccentric adjuster and the clamp with a magic marker or crayon, and see if the adjuster position changes over time. If it moves, then the clamps are not tightened. I had problems with a couple of the clamp bolts cross-threading in the aluminum housing, which made them really difficult to tighten and loosen. If you have the same problem, you should have the clamp threads drilled out and heli-coiled.
Also, if you didn't replace your front and rear sprockets when you replaced the chain, you are probably stretching the chain because of sprocket wear.
Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 13 guests |
