threaded holes in my new headers?
Re: threaded holes in my new headers?
some headers had connections for a gas analyzer.
The thread should be a R1/8 (conical).
The old plugs were #000047113 (now 78010091A). Not sure if #78010071A is the same.
my header
- DSCF9938.JPG (37.61 KiB) Viewed 9601 times
- DSCF9939.JPG (34.68 KiB) Viewed 9601 times
thanks. conical thread huh... the things you learn...
and thanks for the part number. The local dealer had them in stock.
got the washers, too? Applying some anti-seize is recommended.
I was wondering about washers. are they special? or would the right size washer do?paso750 wrote:got the washers, too? Applying some anti-seize is recommended.
use a copper washer
can't find copper. will brass work do you think? the plugs are brasspaso750 wrote:use a copper washer
that should be ok, too. It should just be a washer that also can seal.
aluminum will work and are readily available
I don't understand "that can seal"paso750 wrote:that should be ok, too. It should just be a washer that also can seal.
you want that bolt to sit airtight so you use a washer made out of a softer material than steel
Thankspaso750 wrote:you want that bolt to sit airtight so you use a washer made out of a softer material than steel
