paso oil feeder pipe
Derek
Re: paso oil feeder pipe
Post by Derek »
I don't get it either. The only thing behind that threaded hole at the rear of the crankcase is oil. It would go straight into the sump.
This image is of a 900SS but it is essentially the same.
ducapaso
Post by ducapaso »
In a very close position there's the bypass valve for extreme pressure (spare part manual 066049020 tav 11 #17). It's in the other side of the case but there might be some unwritten modify
