It is currently Tue Jan 22, 2019 8:50 pm
 Post subject: Clutch Noise
PostPosted: Wed Jan 31, 2018 9:55 am
Haven't ridden my Paso for a while. Just pulled the clutch in and I get this loud screetching noise. Would this be rust on the plates or something else? To clean is it just removing the top cover and cleaning the plates? I looked in the Faq and saw some directions on how. Cheers.
 Post subject: Re: Clutch Noise
PostPosted: Wed Jan 31, 2018 7:12 pm
More than likely the release bearing ( part of the clutch slave piston ) Check the FAQ,s as there is a good mod to improve the stock piston assy
H
PostPosted: Wed Jan 31, 2018 7:19 pm
It could be the pressure plate bearing packing up - Just saw that McTool has beat me too it :)
1982 Pantah 500SL
PostPosted: Thu Feb 01, 2018 12:32 am
PostPosted: Thu Feb 01, 2018 11:42 pm
Thanks. I'm selling this bike so I have taken it apart and cleaned it. Gave it a little WD40 and it seems to have stopped.
PostPosted: Fri Feb 02, 2018 9:36 am
So you are passing the problem on to the next owner.
1982 Pantah 500SL
PostPosted: Sat Feb 03, 2018 2:13 am
I've spent plenty fixing mechanical issues on this bike and because I'm too honest for my own good I tell people when there are problems to be sorted. And price accordingly.
PostPosted: Tue Feb 06, 2018 9:34 am
That's exactly what I was thinking. At least if the seller is informed he knows what has to be done.
