It is currently Tue Jan 28, 2020 11:30 am
 Post subject: Rear shock size
PostPosted: Thu Sep 05, 2019 11:45 am
year: 1985
Hi
Can anyone confirm the dimensions for the rear shock?
Length eye to eye- 365mm
Eye holes -10mm
Across flats -22mm
Many thanks
Alistair
 Post subject: Re: Rear shock size
PostPosted: Fri Sep 06, 2019 5:24 pm
the dimensions
PostPosted: Fri Sep 06, 2019 5:33 pm
year: 1985
Hi
Once again, super helpful.
Alistair
PostPosted: Sun Sep 08, 2019 4:42 pm
Hi Alistair,
Maybe this is also interesting for you: the 'technical data sheet' of the Öhlins DU508 shock absorber which was installed on the first 950 or so 750 Paso's. The form is named 'Mounting instruction', but there are no instructions on it whatsoever :) Nevertheless, there are some sizes on it.
PostPosted: Sun Sep 08, 2019 4:56 pm
year: 1985
Ronald
Thank you! It confirms the length.
Alistair
PostPosted: Tue Sep 10, 2019 8:57 am
only in the very early P750 not in the 906 or 907IE
PostPosted: Sat Sep 14, 2019 10:42 pm
year: 1985
New shock...
