It is currently Sat Dec 07, 2019 6:44 am
[ 6 posts ] |
Author |
AmcG
Post subject: Electrical gremlins Posted: Sat Sep 14, 2019 12:22 pm |
Joined: Wed Oct 31, 2018 8:17 pm Posts: 24 Location: UK
year: 1985
Hi
Attachments: |
Top |
Derek
Post subject: Re: Electrical gremlins Posted: Sun Sep 15, 2019 9:08 am |
paso grand pooh-bah |
Joined: Thu Nov 03, 2011 10:13 am Posts: 682 Location: Scotland
The regulator wire carry quite a high current and oxidation of the connector surfaces will create resistance which in turn generates heat which will encourage more oxidation making the situation worse with the result that the connectors eventually burn out, the insulation melts or the resistance gets so high that no current flows. You potentially risk a fire and most certainly a non-charging battery. Replace all the connectors on both sides of the junction with good quality items that are more than up to the electrical current requirement. Also replace any damaged wiring, again using suitably heavy duty wire.
_________________ 1994 907ie 2017 Supersport 939 2015 Scrambler Classic 1982 Pantah 500SL
Top |
AmcG
Post subject: Re: Electrical gremlins Posted: Sun Sep 15, 2019 9:47 am |
year: 1985
Thanks Derek
That is very helpful.
Top |
AmcG
Post subject: Re: Electrical gremlins Posted: Mon Sep 16, 2019 10:04 am |
year: 1985
Hi
Thanks for the links.
Top |
AmcG
Post subject: Re: Electrical gremlins Posted: Sun Sep 22, 2019 2:38 pm |
year: 1985
Thanks in advance...
Top |
[ 6 posts ] |
Users browsing this forum: No registered users and 16 guests |
