It is currently Tue Jan 19, 2021 2:46 am
[ 4 posts ] |
Author |
Fab
Post subject: 2 into 1 exhaust header Posted: Thu Dec 24, 2020 10:32 pm |
Joined: Sat Oct 24, 2020 10:48 am Posts: 8 Location: Australia
i have been looking for a 2 into 1 exhaust header for my bike as mine is starting to crack and rust away. do any other models fit the 750 like the 906,907i or other model 750?
Top |
Post subject: Re: 2 into 1 exhaust header Posted: Mon Dec 28, 2020 3:27 pm |
paso grand pooh-bah |
Joined: Thu Jun 21, 2007 12:00 am Posts: 1492 Location: Gothenburg, SWEDEN
All models mufflers fits but headers don’t, 750 smaller diameter.
_________________ Gert
907 I.E. -91 M900 -97 MTS 1100s -07
Top |
Post subject: Re: 2 into 1 exhaust header Posted: Mon Dec 28, 2020 6:30 pm |
Joined: Wed Dec 05, 2007 12:35 am Posts: 1764 Location: Newzealand
Also the 750 cylinders are not as tall as the 906 or 907 so the heads are closer and the headers are not going to fit. A slightly larger header dia ( like 3mm -6mm larger) is cheap tuning . If you have the old headers as a pattern an exhaust shop may be able to bend up a new set .....maybe even in stainless. I have found that when headers start to crack no amount of welding up the existing cracks will stop the ones you cant yet see from developing further. I made a header for my old suzuki quad and it was obvious that it wasnt quite right as there was a bit of stress getting it all bolted up / mounted , so I heat up the header at major bends ( u bend at ex port and kink around frame ) while still mounted untill just about melting and when it cooled it was a much better fit. I think the pipe sorta did its own stress relieving /alligning thing whilst nearly liquid.
Top |
Fab
Post subject: Re: 2 into 1 exhaust header Posted: Mon Dec 28, 2020 8:15 pm |
thanks for the info, i will look into getting as set of headers made.
Top |
[ 4 posts ] |
Users browsing this forum: No registered users and 21 guests |
