I've just aquired a 750 sport ('92), which is a 88-89 model. I've wanted this bike for a long time!!!
I'm a bit puzzled by the chain and sprockets installed on the Sport. The sprocket on the engine has been made in such a way that it is mounted on the very end of the splined engine axle and fixed with one central bolt. If I take a look at the 750 sport documents and even at the 750 paso I see a different system where the sprocket is installed futher down the axle (towards the engine) and bolted down with two bolts and a little plate. (like my 650 elefant).
I have trouble seeing if the sprockets line up. Which is the right system?
Joep
chain and sprockets
- ir_joep
- year: 1989
Re: chain and sprockets
Got the anwser some posts down. Apparently there are two systems and frames and so on.
Cheers Joep
Cheers Joep
