1990 750 Sport Need Stock LH Rear Blinker -
- velotwin
Hi Guys,
Just bought a 750 S and the rear left blinker is damaged, I'm having no luck in finding one, and refuse to go aftermarket unless absolutely forced to as this bike is COMPLETELY ORIGINAL. Any help is greatly appreciated, possibly even a reward if you hava a spare your willing to part with. Thanks Cheers...
BTW new to the forum, long time Ducati owner will post pics soon of my stable.
- ducinthebay
Re: 1990 750 Sport Need Stock LH Rear Blinker -
Welcome to the site. Lots of info if you read back on the posts.
Good luck on finding that signal. I have bits of 4 of them in the garage, but not enough to make a full one. Rare as hen's teeth. Keep checking ebay is the only way I can tell you, and if someone had one in their hand, and not the bike, they surely wouldn't know what they had.
- velotwin
I think if I had the lens I could get by until a better more complete one is found, thanks for the post and I look forward to reading up on this model, especially the 900ss conversion, as I'm considering storing the orig. Pantah motor which is of course #s matching. My frame has the 6mm shims between the motor and frame, I had a 95 900 SS/SP with the big bore kit, 44 FCR's, V2 cams DP Flywheel etc, and was quite an amazing machine to ride. Now I wonder what it would be like on 16" Oscams? Thanks for the encouraging words, look forward to reading.
velotwin, add your location to your profile.
Do you have a pic of the turn signals ? I guess they were used on other Ducs also. To see what they look like may help finding some.
- velotwin
I'll post an image this weekend. Thanks for the help
Hi
I am not shure if this is any help (since I am not 100% shure on how the rear indicator look like: my bike has aftermarkets). But this item on Ebay is perhaps useful for you?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Best regards
Best regards
750Sport -88 (undergoing surgery)
Pantah racer
450D mk3 -69
900SSie -02
Pantah racer
450D mk3 -69
900SSie -02
- jcslocum
Theyt are rare as hell! Shared with the F1. I have 4 for my F1 and have never seen others.....
don`t they look somewhat like this ?
http://cgi.ebay.com/ebaymotors/Turn-sig ... ccessories
- velotwin
Here is the left blinker showing the lens missing.
- Ducati750S #49 LH blinker.JPG (74.02 KiB) Viewed 7076 times
- velotwin
Here is the RH blinker showing the lens, hope this helps show the size and detail. I appreciate all your efforts, and comments.
- Ducati750S #50 RH blinker.JPG (65.05 KiB) Viewed 7076 times
http://www.ducati-gowanloch.com/catalog ... 8089640533
according to what I found on the internet the turn signal lens is the same from (part#):
CEV 291 9477-8-79-88
Guzzi 23750670 - 30750610
Ducati 067599400
Garelli 5107616501
Malaguti 01900600/700
Aprilia 82.12.032/264/342
Laverda 76.119.264
Ducati 067599400
Garelli 5107616501
Laverda 76.119.264
mate if its is only the indicator lens you need then I think I have one for you. PM me if you still need it. dont have a spare standard screen do you?
cheers
Sean
cheers
Sean
