What Oil?
Mustang505
What Oil?
Post by Mustang505 »
Hi Guys
sure this has been covered a few times before but.......
What oil do you use? Not so much the make but what viscosity? Tell you why I ask:
I was at one of our local race meetings and a some guy who claimed to be a "Ducati Mechanic" asked what oil i was using - told him Castrol R4 Superbike 5W-40. Big fowns and shakes of the head "not right you should use at least 20W-60" Really? He then went on further to say it will cause most problems with the operation of the clutch..................that's when i stopped listening.
I have been using this oil for over a year now and have done 7 race meetings and it been all good. Is 5w-40 too thin for our motors?
Clive
Re: What Oil?
0w-40 here,full synthetic
I don't think I'd use 5w-40
Re: What Oil?
I`m running 20W-50 as recommended in the user manual. (Used Castol mineral in the past now AGIP synthetic)
Re: What Oil?
... some guy who claimed to be a "Ducati Mechanic" asked what oil i was using ... He then went on further to say it will cause most problems with the operation of the clutch ...
Unless you have an engine conversion the next time you see this guy you tell him you have a dry clutch. ;)
Mustang505
Re: What Oil?
G - hence why i stopped listening to the guy...........
I had to show him the holes in my clutch cover to prove it's a dry clutch!!!
Higgy why 0W and why not specifically 5W? Just means at winter tempertures 0 is slighty thinner than 5. I was more concerned about the 40 but having done a fair bit of research now a 10W40 semi or fully synthetic is recommneded by most for our engine.
Clive
Re: What Oil?
0w is completely different than 5w
0w dies not change viscosity regardless of temp
Andrew2
Re: What Oil?
Post by Andrew2 »
I've run 20/50 mineral in all my bikes ( except the bevel and that could change soon as well) and have never had a problem.I'll be putting the same in the Sport when it's time.
A2
JoKing
Re: What Oil?
Post by JoKing »
Bevel: HD50 Oil
907 w ST3 engine: 10W50
The lower number can roughly be seen as the value for the viscosity when cold-starting the engine.
The higher number shows abstract the temperature where the critical viscosity is reached.
My Bevel is nearly never "cold started" so it gets the HD50...
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
