Hello again. Hope I'm not making too many new topics.
Whilst on a 198 mile run I pulled in the clutch and heard a loud rubbing noise (even in neutral.)
It doesn't do it every single time I pull the clutch in, and the clutch is brand new (like 2 months old tops.)
It has plenty of oil in the engine, what could it be?
Really worried.
Also has brand new tyres
Cheers, Alex
Rubbing noise
- year: 1989
- ducinthebay
Re: Rubbing noise
Pull off the clutch cover to see that everything is good inside. If there is spare bit dancing around inside, it may give you an intermittent noise. Its only a few bolts, and you should clean it up every once in a while regardless (unless its vented as some covers are)
- year: 1989
Re: Rubbing noise
I was panicking alittle bit as the clutch is only months old the end of the lay shaft was rubbing against the case (looked like abit of rust) so I cleaned it up and put abit of heat proof lubricant on the end and its fine. Will check it again over winter.
Re: Rubbing noise
If you listen for funny noises you will always hear them. I found the paso to be a noisey bike .... not engine ... well that too but wind noise , road noise ( and that changes depending on road surface ). Probly the easiest guide ( thats GUIDE not one of Moses's tablets!), most noises that keep time with road speed are either chasis related ( wheels, brakes ,chain ) or road/wind noise . Noises that change with engine speed ( change gear whilst maintaining same road speed ) are probly the engine/gearbox.
- year: 1989
Re: Rubbing noise
I found that out with my old CBX750. Constantly paranoid about knocking noises, because of the cam chain issue. Eventually it knocked really really loudly (saying loudly sounds wrong to me?) anyway it knocked for a good 3 months. Even after a service it knocked, eventually it went bang... due to lack of oil (unknown oil leak) so the knocking couldn't have been anything to worry about. I'm paranoid about the ducati though, it's the newest (mileage wise) bike that I've owned. I'm proud to own a ducati and am even more proud to have a noisy one
Re: Rubbing noise
A cbx 750 huh , I had one of those ..... biggest heap of shit I ever owned.... god took care of it for me ... I was sitting in a row of stationary traffic wondering how I could get shot of this peice of shit without loosing to much money .... and someone ran up the arse of me and solved all the problems. rattly primary chain ,noisy lifters ( yeah they were hydraulic ) used heaps of oil ( 1l /1000km's ) and was tapped at 180km/h. It would be a toss up between that bike and a xv750 for the" most useless bike I've ever owned" award
