Hi All, You may remember me asking if anyone knew if anyone made a carbon fiber rear hugger for a 750 Sport. Well after no luck it was suggested I tried wrapping it with the 3m Carbon look alike wrap. Although the actual wrap looked very realistic it failed to drape well around the curves so I gave up on that one. It was then suggested that I got it carbon dipped via Hydrographics. This has come out very well and has turned the pretty ugly large dull standard hugger into something a little more appealing...at least to me anyway!
So I thought I would attach a couple of pictures of it for any of you who may be interested.
I also may now have found a source for a real carbon one so I will advise details on here if that proves successful.
Carbon Hugger Update
- year: 1989
- IMG_2571.jpeg (108.37 KiB) Viewed 7717 times
- IMG_2572.jpeg (108.01 KiB) Viewed 7717 times
- ducinthebay
Re: Carbon Hugger Update
Wow, that is amazing.
Not only that they would do a one off, but also that they got that to stick to polypropylene.
At my Sport there is a real-carbon rear hugger, but I have no clout where it comes from.
Cheers, Marcel
Cheers, Marcel
Marcel
Ducati 748S ('99)
Ducati 750sport ('88)
Husqvarna 450RR ('07)
Ducati 748S ('99)
can you post some pictures (specially from the left side)?
G:
G:
- year: 1989
I also now have a real carbon Hugger. They are made by Diopa in Germany. basically it's a shorter version on the standard one above using the same locating holes as the 87-90 version sport. They list quite a few other things but this is the only one they do in Carbon. They are not quick at replying and struggle a bit with English! But quality was good, you have to drill the holes yourself but they are marked from the moulding process. Here's the link:-
http://www.diopa.com/shop/shop.html
- year: 1989
Carbon Hugger on Bike
- IMG_2599.jpeg (135.62 KiB) Viewed 7557 times
- year: 1989
More Pics, with the original (now Hydro carbon coated) hugger next to it. The real carbon one doesn't cover the chain like the original.
- IMG_2574.jpeg (125.41 KiB) Viewed 7556 times
- IMG_2576.jpeg (104.58 KiB) Viewed 7556 times
- IMG_2577.jpeg (102.56 KiB) Viewed 7556 times
- year: 1989
that looks like a standard SS hugger with the mounting tabs removed & shortened a bit
http://www.geelongcarboncraft.com.au/pr ... ugger.html
- year: 1989
Similar but made for the sport. This is the listing:-
Vorheriger Artikel Liste 'Kotflügel vorn/hinten' Nächster Artikel
Kotflügel, hinten, "Superlight-90", ähnl.Orig., Duc 750/900, Bj.87-90, KF
C0156
Lieferzeit: ca. 10 Tage
Preis: 156.00 EUR
In den Warenkorb
C0156
Preis: 156.00 EUR
In den Warenkorb
