It is currently Wed Mar 20, 2019 5:10 am
 Post subject: Clutch adjustment
PostPosted: Mon Jul 04, 2016 7:40 am
Dear All,
I have installed a new clutch on my 89 Ducati 750 Sport and it runs fine with it.
But the clutch point is still very late on the lever.
How can I adjust the point where the clutch "bites"?
Thank you and Rgds,
Marcel
Marcel
Ducati 748S ('99)
Ducati 750sport ('88)
Husqvarna 450RR ('07)
 Post subject: Re: Clutch adjustment
PostPosted: Mon Jul 04, 2016 8:44 pm
Late ... to engage ... as in lever is almost right out before bike moves off ? , probly not a bad thing as this would mean the clutch is well bled. If the lever span is to big , if the rider has a small hand then an adjustable lever is probly the best way .
https://store.bevelheaven.com/Brake-Rel ... ivot-bolt/
On this lever you can just see the end of a screw that bears on the cylinder piston , a non adjustable lever may have this screw and this may provide the adjustment you need :)
If its the opposite , lever has to be pulled right to the bar to stop bike creeping forward you probly need to bleed the clutch better ( and they can be a proper bastard sometimes ) :)
PostPosted: Tue Jul 05, 2016 1:55 pm
Great! It worked out with the screw!
Thanks alot!
Marcel
Ducati 748S ('99)
