It is currently Tue Feb 19, 2019 9:05 pm
 Post subject: sump nut or plug
PostPosted: Fri Feb 03, 2017 7:24 am
hi does anyone what direction plug should be turned to take out to drain oil? i am not sure if i am turning the wright way
 Post subject: Re: sump nut or plug
PostPosted: Fri Feb 03, 2017 9:29 am
If you are looking at the nut/plug/bolt (whatever it is) you have to turn counter clockwise; against the normal direction of a clock).
So, if you want to unscrew the oil plug (underside engine): lying on your back looking/eyeing against the underside you turn the wrench against the clock.
Good luck, if something is not clear just ask me!
Ciao,
PostPosted: Fri Feb 03, 2017 9:34 am
Sorry, 1 thing: be sure you pick the right plug!
There are more than 1 (you need the plug which is in the middle of the engine, on the rear side of the crankcase ... the big one).
PostPosted: Fri Feb 03, 2017 9:43 am
And it has a 10mm hex socket head. Make sure your key is a good fit in the socket, they have a nasty habit of rounding out.
1982 Pantah 500SL
PostPosted: Fri Feb 03, 2017 9:14 pm
And don't forget the strainer on the lower right hand side of the cases .................which turns the same way
PostPosted: Fri Feb 03, 2017 10:51 pm
model: other
The owners manual is readily available on the site for download, it has all the basic info you'll need to most things
https://www.box.com/shared/pbgnkjcxlq
Plus this thread has nearly every other thing you'll need, heaps of technical and other info
viewtopic.php?f=1&t=1551
This should get you started
for what your doing just think Lefty Loosy - Righty Tighty when undoing or tightening things up, sounds silly but lying on the ground working underneath a bike or car, it is easy to get confused, well me anyway... :truck:
Also if you don't have one, well worth investing a in Torque Wrench.
Hope this helps
