It is currently Sat Feb 16, 2019 9:21 am
Post new topic Reply to topic  [ 353 posts ]  Go to page Previous  1 ... 19, 20, 21, 22, 23, 24  Next
PostPosted: Fri Aug 31, 2018 11:16 am
Just fitted the revamp dash and gauges , ordered some much needed stuff from s/d germ any, gone from no work to 7 days a week till December .
PostPosted: Thu Oct 04, 2018 10:44 pm
New coils are in and waiting on a lot of stuff from o/s to button up the mechanical side of things
PostPosted: Fri Oct 05, 2018 4:03 pm
Stay healthy and get rest while you go at 7/wk. Take extra care to avoid losing focus. :-)
PostPosted: Sat Oct 06, 2018 2:02 am
Yeah thanks mate it's a bit crazy , working a swingstage painting external 25 level building in perth but at least its giving me the money for finishing the Duke so happy days
PostPosted: Wed Oct 17, 2018 11:29 am
Recently got my new s/ hand lights and go switches and still waiting for lots of bits from s/d Germany , some parts on backorder and don't want the double postage, and the fork bling not politically correct but same as a Mk 3 lemans I had with the 38 mm marzochis and polished aluminum legs
PostPosted: Wed Oct 17, 2018 11:43 am
PostPosted: Thu Nov 15, 2018 12:35 pm
I get the fcr 41's tomorrow so I have polished the inlet ports
Internally and externally, I'm still waiting on many parts from Germany S/D , they are damn slow but if they can find some obscure bits I'll be happy, like those tapered rubber hoses to the engine breather, new indicators and a couple of small bits, I guess the choke lever will become spare parts to keep with the mikuni which I will keep working on
PostPosted: Thu Nov 15, 2018 12:38 pm
When I get the new clutch locator piece I will remove the clutch cover and see about getting some pictures of exactly how the Barnett plates sit and fit
PostPosted: Thu Nov 15, 2018 1:22 pm
why did you polish the inlet ports? The surface shouldn't be too rough but it shouldn't be polished either.
PostPosted: Thu Nov 15, 2018 10:43 pm
Brutally honest would be cause I'm not as clever as I thought I was and a mate suggested that move, on the bright side I only used some scotchbrite and water so maybe didn't alter the surface that much, I'm living and learning , thanks your knowledge seems endless
PostPosted: Fri Nov 16, 2018 1:11 am
Yeah the surface roughness helps with fuel/air mixing (micro turbulence). port matching is a bigger issue because repeals can change the air speed in undesirable ways. standard green scotchie is pretty smooth though... actually just realised i don't know if everyone uses the same colours for scotchie grades: green, cleaning things - grey, taking the gloss off paint (about the same as dry 600 grit) - red, taking paint off (about the same as dry 400 grit)?
PostPosted: Fri Nov 16, 2018 11:56 am
Thanks bluey maybe some lite I used the old red stuff, carburetors turned up today
PostPosted: Fri Nov 16, 2018 10:40 pm
Do you recommend refitting these inlet ports or trying to source a non vandalized set
PostPosted: Sat Nov 17, 2018 11:22 am
PostPosted: Sun Nov 18, 2018 9:40 pm
Oh my, look at those beauties, I can hear the intake roar from here!!
Fraser.
750 Paso
1980 Moto Morini 500 Sport
1979 Moto Guzzi V1000 Convert
