Oil leaks 89 900 ss
- model: 900 SS
- year: 1989
Re: Oil leaks 89 900 ss
Yeah I use my phone, I think I may need to close maybe shutdown this membership and try start again, all turned to crap when I did NBN switch with my mobile phone network, pretty annoying, this is a great forum
- model: 900 SS
- year: 1989
Just waiting for gauges to return from speedline instruments in perth for 2nd time as I had to replace the reset shaft on speedo and also refit new satin black powder coat bezels, chrome just wasn't right, oil cooler/ lines/ headlight/ wiring can then be connected and I'm off to protwins for Justin to work his magic. Soon as she's out the door I will start the painting process and when she returns I will be leaving her in my lounge till the painting is done, good times, on target to finish for xmas, been a long time coming but getting there, Rob.
- model: 900 SS
- year: 1989
Well this is good, I've just closed my Facebook account and for the first time I can post pics again, not sure if coincidence or what but certainly happy days
- model: 900 SS
- year: 1989
Still moving along , clutch out again though as the paint on the cover was cracking, too many coats,!, nearly back together, life is getting in the way a bit, still on track to start up before xmas
- model: 900 SS
- year: 1989
Just about to tighten the clutch control/ spring retainer and second guessing whether you tighten down to the posts, ie far as you can go, or you measure and set somewhere in between, learning ,, thanks for your interest cheers
- IMG_16122018_170835_(1024_x_768_pixel).jpg (416.81 KiB) Viewed 6373 times
- model: 900 SS
- year: 1989
Not sure how or why I managed to post this pic but I will definitely be posting pics of this bike till its finally up and running, your input / continuing interest will be rewarded with all the painting and prep just need to sort out this pic uploading problem
- model: 900 SS
- year: 1989
That's a pretty old pic, guages bevels now satin black powdercoat, ignition decal , k + N soup cans, and bits , new grips etc
- model: 900 SS
- year: 1989
Just finished the clutch cover replacement, this original cover came up well paintwise, pretty happy with the way it all went, definitely learn more when you have to repeat processes, haha its happened a few time with me on this bike
- randtcastell
Thanks for the update and photos! Great carpet. :^)
1987 Ducati P750
1973 Honda CB450
2022 KTM RC390
1973 Honda CB450
2022 KTM RC390
- model: 900 SS
- year: 1989
Shes off the bench and standing on her own albeit with the shitty original sidestand, I have another longer stand but needs some modifications to clear the exhaust, off to Justin next Saturday , happy days
