Page 16 of 42
Re: Oil leaks 89 900 ss
Posted: Tue Jan 16, 2018 9:21 am
by Derek
I have one of these. Works a treat and so simple.
Posted: Wed Jan 17, 2018 2:17 am
by HIGHWAY89
Thanks for the tip I just ordered one of those clutch tool, on another note anyone had any experience with the wavey discs coming from chengzen or wherever in China as I'd like to update mine but original pretty pricey
Posted: Wed Jan 17, 2018 2:29 am
by HIGHWAY89
- IMG_17012018_102650.jpg (395.77 KiB) Viewed 6733 times
I wish I had that tool last week as now I have committed to running the bike into protwin to sort out this clutch but atleast he will get to the bottom of this and I can post results which may clarify some details which could help others in the future, cheers, here is the dismantling pic which shows the plates sitting how they should
Posted: Wed Jan 17, 2018 5:12 pm
In the 907IE FAQs you find a list of bikes that use interchangeable brake rotors.
Posted: Sun Jan 21, 2018 2:58 pm
by HIGHWAY89
MCTOOL, your clutch tool is really similar mate, I copied yours, cheers just my fabrication skills leave a bit to be desired
Posted: Wed Jan 24, 2018 10:49 pm
by HIGHWAY89
- IMG_25012018_064020.jpg (345.44 KiB) Viewed 6649 times
Bikes back from Protwin with clutch sorted, Justin removed the clutch nut and stripped back to check all and only problem was the order of plates, I may remove plates to see correct order and take a pic as I still need to change the control plate for a new one, here's a pic of what's left of original clutch and barnett clutch , cheers
Posted: Sun Jan 28, 2018 8:10 am
by HIGHWAY89
- IMG_27012018_123448.jpg (481.78 KiB) Viewed 6627 times
Posted: Sun Jan 28, 2018 5:31 pm
by randtcastell
WOW.
Tell us about your front brake rotors please.
Thank you again for documenting and sharing your incredible restoration. It's golden... :-)
—Randy
Posted: Mon Jan 29, 2018 3:14 am
by HIGHWAY89
Thanks Randy, the front rotors are possibly getting changed for new as I need to replace the rotor screws for new ones and same on rear so considering new rotors while I'm at it, the gold rotors are really just the results of a lazy repaint, the idea being first running old pads to cut a nice outer circle in paint, I'm looking at the Chinese stainless discs as reasonably priced but if anyone knows of any problems with these I'm all ears, thanks again
Posted: Mon Jan 29, 2018 3:17 am
by HIGHWAY89
- IMG_29012018_111653.jpg (393.47 KiB) Viewed 6604 times
Posted: Tue Jan 30, 2018 1:23 pm
by HIGHWAY89
- IMG_30012018_211452.jpg (282.12 KiB) Viewed 6579 times
Just fitted new orings and screws to the barrel/ piston oilfeed pipes, can I replace with pipes off later 900 ss as these are no longer available for this year, thanks
Posted: Tue Jan 30, 2018 4:29 pm
by Derek
Well they will fit the engine but I don't know how well they will line up with the silencers. I'm sure someone will have a definite answer
Posted: Wed Jan 31, 2018 10:56 am
by HIGHWAY89
Thanks Derek, but I'm talking about the little oilpipes from the alternator cover to the barrels, the old ones are a bit knackered mate
Posted: Wed Jan 31, 2018 7:17 pm
by Derek
Sorry, I guess I wasn't paying attention. Unless they changed the size of the banjos, and from your photos they look the same, then I'm sure the oil pipes will fit. They are flexible so will allow a little a bit re-alignment if necessary.
Posted: Tue Feb 06, 2018 10:30 am
I'm still lost with the clutch issue. The tolerance between a new and a worn clutch is small so I wonder which status you're in now by using another clutch with two discs removed. Didn't you also say the new kit was actually thinner than the old one?! However, if it works it's all good. For me it just shows it's not the correct clutch and that it would have been better to return it and get the right kit.
Regarding the oil hoses I guess a hydraulics shop could make some. If the size of the banjo fittings is the same as the ones used for brake hoses (and if the inner diameter is about the same) you could also make your own. That's assuming that a hose that is made for brake fluid can also handle engine oil. You can find brake hoses which can be cut to the length you need. I.e.
https://revivalcycles.com/products/brake-lines
