It is currently Sun Jul 05, 2020 11:21 am
 Post subject: Gas leakage from carb, 750s
PostPosted: Thu May 31, 2018 6:17 pm
What is this part of carb and how can I prevent it from leakage? When turning the gas handle this part moves and starts to drip a little gas over time...
 Post subject: Re: Gas leakage from carb, 750s
PostPosted: Thu May 31, 2018 8:26 pm
That's the accelerator pump. There's a membrane behind the cover that may need to be replaced.
PostPosted: Fri Jun 01, 2018 10:58 am
http://stores.ebay.com/ALFA1750S-CARBUR ... ORE?_rdc=1
https://www.ebay.com/itm/WEBER-40-42-44 ... 43a165f925
PostPosted: Fri Jun 01, 2018 2:21 pm
Got one from local bike part seller. Hopefully it is the right part :)
PostPosted: Fri Jun 01, 2018 7:19 pm
All Weber DCNF's use the same one
PostPosted: Fri Jun 01, 2018 7:22 pm
That fixed it! Great, once again thanks to you guys :)
This also fixed the rushing issue and bad idle running I had in my other post.
