It is currently Fri Aug 14, 2020 7:06 pm
 Post subject: fuel pressure regulator
PostPosted: Sun Sep 08, 2019 12:25 am
hi
whet regulator should I get for my 750 sport with webber carby also what should I look for to get gasket kit and new needle and seat my carby floods plugs are always black
thanks
jim
 Post subject: Re: fuel pressure regulator
PostPosted: Tue Sep 10, 2019 9:15 am
It shouldn't be a problem finding a gasket kit. The only difficulty I had some time ago is getting the thick gasket that sits between carb and carb manifold.
Is there an Y-piece in the fuel line with a return to the tank? There should be. If there is there will be a 120 Dellorto jet in the Y-piece's exit returning to the tank. You could try to remove the jet and/or turn around the Y-piece so it splits towards the carb and the tank return. Maybe this will be enough to reduce fuel pressure.
If you get a fuel pressure regulator it should be one with 3psi max.
