It is currently Thu Sep 24, 2020 2:15 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: 750S Brought back to Life
PostPosted: Thu Apr 02, 2020 8:58 am
Thanks for establishing this centralized source of information for these unique machines. I brought mine back to functional use over the past week and would like to share with you all.
File upload function wasn't working right for me so I created a shareable link: https://photos.app.goo.gl/vaN9vDn7NHBAdFgP6
Enjoy!
I'll be poking around other parts of this website :)
Thanks,
Roger
 Post subject: Re: 750S Brought back to Life
PostPosted: Thu Apr 02, 2020 11:43 am
Gorgeous. Resplendent. Excellent. Praises! Thank you.
PostPosted: Thu Apr 02, 2020 2:40 pm
Gorgeous, well done!
PostPosted: Fri Apr 03, 2020 9:13 am
Nice. I see the bike has been fitted with USD forks and brakes from the later models. Should be a worthwhile improvement.
PostPosted: Fri Apr 03, 2020 3:51 pm
Very nice project. What forks did you use? I have got hold of some 17 inch wheels from a 600ss for my 750 sport. I may just go ahead with this mod initially. As posted elsewhere I think my only issue is machining a slice out of the original forks to get the speedo drive in. Again as previously posted the current 40mm marzzochis have had some internal work done by maxton. Not sure if this will just make them acceptable by modern standards and still some way off what the USD forks will offer or as good as the USD forks. Have you had a chance to gain an opinion on the USD forks
Best regards
Keith mm
PostPosted: Sat Apr 04, 2020 5:05 am
Best regards
Keith mm
Keith,
The bike was a project by the PO that lost interest and wanted to get rid of it. Much of the cosmetics and mods were his. Lucky me? :)
The adjustable Showa forks came from a 900SS/M900 with the 40 mm caliper mounts. The matching triple tree was off an SS with 50/54 clamps. Wheels likely came from an SS with 120/60 front and 160/60 rear tires. I don't know which bike the swingarm came from but matches up to rear wheel, sprocket, and axle. The speedo drive internal gearing resulted in a higher speed shown than actual. I swapped internals from a spare working SS speedo with a cracked housing. Your M600 wheels may likely work with the 90's era Showas. Though using the Marzocchi would avoid searching for a triple tree. Once I set the sag and damping, the inverted Showas work very well. The modern suspension mod was the upgrade I appreciated the most because they are in high demand, especially among the SS community, making them tough to find. If you have trouble searching out a set, I would buy a pair of non-adjustable Showas (found on ebay for pretty cheap) and drop in an aftermarket cartridge kit.
The bike wasn't running when I got it and spent most of winter getting it to run right:
-Ignition had a weak spark due to a bad battery. I swapped the original coils and cables with the California Cycleworks type, along with a new battery to start fresh.
-Carburetors were running too lean and now set to where I think is good (or at least in the right direction).
-Charging system was tested to be bad (no change in voltage after 3,000 RPM). I put in an Electrosport regulator/rectifier.
-The front sprocket, while correct for a stock 750 Sport, was not correct for the SS rear sprocket. Also, the worn spline retainer didn't help. I had a spare front sprocket off a 996 with the same number of teeth and lined up straight with the rear sprocket. The retainer plate was also replaced :)
Getting all of the above sorted out and going out on an actual joy ride over the past few weeks has been immensely rewarding :D
I may not have a Paso, but a close cousin with some modern upgrades feels just as good!
-Roger
PS - A link to some pics I collected since Day 1 :)
https://photos.app.goo.gl/dVciJTed54L1Rn447
PostPosted: Sat Apr 04, 2020 6:51 pm
Hi Roger,
Many thanks for your comprehensive reply. I think you have a very sweet bike there. All the benefits of a modern bike wrt suspension, brakes and rubber in a nice sounding package that will just beg to be thrashed. I must admit I have lost the joy of modern 150 bhp Ducati’s as I ultimately just love thrashing a bike to within an inch of its capabilities on a run on a sunny afternoon run. Something you just cannot do on a modern bike as before long you will be in a ditch or dead. Enjoy
Best regards
Keith mm
Ps I believe there is such a thing with aircraft called a flight envelope. I think something similar must exist for motorcycles. A spitfire (insert your own national treasure of a plane here) has a significantly smaller flight envelope than say a euro fighter (again insert your nations stupidly expensive airplane here). However, pilots wax lyrical about the utter joy of flying those old machines. I think the same is true with motorcycles. Good tyres brakes and suspension are clearly a great idea but you don’t have to stupidly high amounts of power to make an engaging machine. Rant over!
PostPosted: Sun Apr 05, 2020 3:49 am
Magnificent. And I'm with you on thrashing these things. They are built for it and I love it.
life is Awesome
907ie
900ss FE
900ss ie
750Paso {sold}
Aprillia Tuono {sold}
Honda Firestorm {sold}
I only count the V twins
PostPosted: Sun Apr 05, 2020 3:50 am
life is Awesome
907ie
900ss FE
900ss ie
750Paso {sold}
PostPosted: Sun Apr 05, 2020 6:02 am
Keith, I agree as well. I find ripping up a "slow" or older bike more fun than a modern high powered machine. Other similar bikes are my 900SS and Moto Guzzi V7 Racer, both of which I love tearing through the rev range. Like the 750S, they both have adjustable suspension matched to my weight. Pure enjoyment. :D
PostPosted: Sun Apr 05, 2020 6:10 am
I also think many riders on this forum have a bigger appreciation of the older stuff over modern machines, and happy such a place exists. I first saw the Paso in a black and white photo as part of modern Ducati history. That Paso, the 90's SS, and variants in between are what I see as classic Ducati.
PostPosted: Sun Apr 05, 2020 6:43 am
Some pics I collected since Day 1 :)
PostPosted: Tue Apr 07, 2020 10:59 pm
Yes mate that is one awesome bike you have, you've got what started life as a real contender and turned it into an absolute winner,inspiring others along your way ,thanks for sharing and inspiring
PostPosted: Thu Apr 09, 2020 7:52 pm
Better to ride a slow bike fast than a fast bike slow!
PostPosted: Tue May 12, 2020 12:08 pm
model: other
year: 1999
Great job and excellent update interpretation of the style. :thumbup:
I note that it has Mikuni TM carbs. Are they TM36 or 38's and are you happy with them? What jetting did you have to run with pod filters?
I am thinking about putting a kit together for 750 and 900 desmos as an alternative to the very expensive Keihin FCRs.
2013 M1100Evo Street
1999 M750 "Scrambler"
2004 GSXR750 Track
