Fellow members,
Do any of you know where I can get some mirrors for my Paso?
Paso 906 Mirrors
- persempre907
- persempre907
I bought them on eBay.
Here there is an old kind mirror http://cgi.ebay.it/ducati-paso-750-mirr ... dZViewItem
while in the link below there is a Freccia type
http://cgi.ebay.it/Ducati-Paso-Spiegel- ... dZViewItem
I bought Paso's spare parts from both the sellers. Try asking them.
Replacement glass
Damaged glass can be replaced with a chinese copy of a Yamaha trailbike mirror 100mm diameter and glue it in with silicon rubber. It looks exactly the same as new and has the same focus / perception as the original, cost about Au $11:00
The actual plastic can be fixed with fibre glass ribbon and expoxy and re painted or Body Builders or Surf board makers can help you with that.
Blinker Lens - Thats the hard part, the internals can be knocked up from anything and reflective contact can be used (like the cheap sit on lawn mowers have) you can get it from 2 dollars shops, they use it for handicrafts. The Lens I have no answer other than Ebay and Wreckers with a little praying.
If your bike is red - there is a spray can that's very close it's a Toyota red touch up paint. If yours is like mine you need to take the damaged mirror to a paint shop and have them mix up the correct colour or get it sprayed and ask for a 500ml container for touch ups.
Nothing is impossible! well maybe a dodgy seat base, that's hard to fix
