1990 906 Paso Thermostat
CruisininVA
Post by CruisininVA »
Hello,
I recently purchased a 1990 906 paso and the thermostat went bad along with the hose. I was wondering if anyone new where i could purchase one. Thanks.
Jerry
persempre907
Post by persempre907 »
Where are you from?
CruisininVA
I'm in Virginia. But i will make arrangments if necessary. Where are you?
persempre907
Rome, Italy.
So unfortunately, I can't give you any good advice to find it.
I hope some US member will help you soon.
marshman
Thermostat
Post by marshman »
Howzit
Parts all available ex your local Ducati dealer.Guy in NZ, Phil @ desmocycle@paradise.net.nz recently dismantled one.Try him!
Cheers Andrew
ducatipete
Post by ducatipete »
Its the same as fitted to 907 bike. My local UK Dealer, Pegasus has 907 parts on their computer but not 906. Don t think you can fit one from a newer bike as elbow connections are different. To check thermostat put into boiling water and see if it opens, ideally use a thermometer good luck :thumbup:
