Hi everyone and Happy 2008!
I recently installed a set of 900ss mikunis on my 90 906 paso. I had to construct an air filter set up using 2 K&N air filters. It works, but its probably the most hideous thing you'll ever see!
My question for you is what filters have everyone else been using with success? I have no factory air box to work with, so thats not an option. Ideas anyone? Thanks for your advice in advance and ride safe!
906 Mikuni conversion filters
- Finnpaso
- year: 0
Re: 906 Mikuni conversion filters
I converted jst some mothes ago my 750 Paso to Mikunis with Dynojet kit stage 1. and i used quite similar bomull pod filters, as K & N are, but they were some much cheaper model mande in far east, anyway liiks same, as much expensive. Price was 14€ / 2 filters. I havent driven my bike yet, but seems, that it runs well outside garrage. Test drive shall happen next April, or may....
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
hi
of how they sit within the frame rails and also photo's of the way the wiring harness is routed on the bike thanks bob
hi badhabrace i just got 900ss carbs to fit on my 906 can you take some photo'sbadhabrace wrote:Hi everyone and Happy 2008!
Bob,
here some pictures of my Mikuni TDMR carbs and a friend`s ex-906 with Keihin carbs. Also with original Mikunis the position in the frame is the same.
You will find more info in the P750 FAQs.
