It is currently Tue Feb 19, 2019 11:00 pm
 Post subject: problems with the clutch
PostPosted: Thu Jun 09, 2005 6:54 pm
hello,
i'm from Belgium and I just bought a paso 906.
When the engine is cold the clutch makes a weird sound.
when he's warm, it's over.
What could it be ?
thank you :-)
koen
 Post subject: Re: problems with the clutch
PostPosted: Sat Jun 11, 2005 8:30 am
koen524 wrote:
hello,
What could it be ?
thank you :-)
koen
like in this topic?
http://forums.ducatipaso.org/viewtopic.php?name= ... opic&t=375
Have you cleaned the plates yet?
| '92 907 I.E. | '88 750 Paso under construction |
PostPosted: Sat Jun 11, 2005 2:48 pm
And does the sound disapear when you pull the lever in ? :roll:
PostPosted: Sat Jun 11, 2005 4:20 pm
when I pull the lever in, it's over.
PostPosted: Tue Jun 14, 2005 12:30 am
refer to the link in DuC-Man' s post above, do the same fix I did (4th last post in that link) & all should be good :thumbup:
Redpaso
