Help finding new Starter Sprag
- year: 1989
So yeh where do i start looking for this part?. I did read on another web-site that the Sprag from a KTM LC4 Motor will fit ( 640cc ?) but my local helpful Ducati / KTM Parts supplier is as about as much use as an Ash Tray on a Motorbike when i contacted him. So yeh help would be much appreciated and any thanks in advance.
Re: Help finding new Starter Sprag
G'day Harry
Have you had the engine apart to determine the condition of the sprag clutch? You may want to have a read of these web sites. You might only have to replace the spring at a fraction of the cost of a new sprag.
http://www.perthstreetbikes.com/forum/f ... tch-85481/
http://www.mad-ducati.com/Technical/Sta ... lutch.html
http://www.mad-ducati.com/Technical/Eng ... over2.html
I've had to do it to mine, just remember to wrap tape around the cams as soon as you get the sprag out.
Bevel Heaven also sell a sprag that they claim ( and Im sure they are right ) will fit a paso among others . I have had excelent service from them in the past
- Jaffa
I replaced the sprag in my 907 with a 900 monster version....a couple of years ago now, but still working well.
Try Ian Gowanloch, or Gowanloch Ducati or Road & Race. There are plenty of places here in Oz that can help you out.
If you get in quick enough though, the $ is still over parity so it may be worthwhile getting one from Bevel Heaven. There are dozens of sites around that will have these.
Cheers.
Cheers.
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
'91 907ie (RED)
- romus
From my research I found the Ducati part 70140011A corresponded to the KTM part 58440026000. You will read on-line that it goes on backwards for the Ducati. That's easy to see - one side has a left directional arrow the same as the Ducati one (facing you as you look at it when it is in). So, that side is put in the same as the one you take out. There is a KTM circlip you take off the back and I used the original Ducati circlip (thicker) to put it back in.Harry wrote:So yeh where do i start looking for this part?. I did read on another web-site that the Sprag from a KTM LC4 Motor will fit ( 640cc ?) but my local helpful Ducati / KTM Parts supplier is as about as much use as an Ash Tray on a Motorbike when i contacted him. So yeh help would be much appreciated and any thanks in advance.
I ordered mine from http://www.speedaway.co.uk for a total of 66.45 pounds, which included 20 pounds freight. On their site it is under FREE-WHEEL FWD 332008 BLS (58440026000). That was the cheapest I could find to Australia.
You will find various posts which talk of ways to shorten or simply replace the spring - I just wasn't game to try that.
I also ordered a Heat gun (http://www.ebay.com.au/itm/ws/eBayISAPI ... 0703782254) so I could get that crank shaft bolt off. 20 minutes of heating to do it - for sure it needed that method.
For putting it back together I ordered Loctite 648 from https://www.bolt.com.au/loctite-648-ret ... -7673.html. Also I got a replacement gasket for the alternator cover.
Having put mine in, I found it fixed the clunking noise I had and also the motor turns over correctly for starting :-)
Ducati Paso - Soul of a thoroughbred
- romus
From my research I found the Ducati part 70140011A corresponded to the KTM part 58440026000. You will read on-line that it goes on backwards for the Ducati. That's easy to see - one side has a left directional arrow the same as the Ducati one (facing you as you look at it when it is in). So, that side is put in the same as the one you take out. There is a KTM circlip you take off the back and I used the original Ducati circlip (thicker) to put it back in.romus wrote:Harry wrote:So yeh where do i start looking for this part?. I did read on another web-site that the Sprag from a KTM LC4 Motor will fit ( 640cc ?) but my local helpful Ducati / KTM Parts supplier is as about as much use as an Ash Tray on a Motorbike when i contacted him. So yeh help would be much appreciated and any thanks in advance.
- year: 1989
Thanks for the advice everybody. I am just waiting for the Courier to drop my new Sprag off which i ended up getting from Bevel Heaven. Once it arrives it will be time to chill the Beers, break out the Spanners and start throwin them around.
