I have a 1990 paso 906
nic42
Post by nic42 »
the problem im having is the speedometor is not working what can i look for? :banghead:
900streetfighter
Re: I have a 1990 paso 906
Post by 900streetfighter »
Hello And Welcome. Take the nose cone off (6 screews), unscrew cable where it goes in speedo. check inner cable turns when front wheel turns. Hopefully its the cable snapped or the drive broken. Either are cheap and easy to replace.
nic42
Post by nic42 »
ok thanks,ill try that :)
