It is currently Wed Feb 24, 2021 8:55 pm
 Post subject: starting problems
PostPosted: Sun May 20, 2012 7:21 pm
oi guys, long time no see,
i'm having problems starting, did a overhaul at the startingengine, its not the problem now.
it seems to be a problem with a sprocket behind the generator, anyone ever encountered a problem
like this?
 Post subject: Re: starting problems
PostPosted: Sun May 20, 2012 8:03 pm
are you talking about the infamous starter sprag? - is the starter failing to turn over engine and making a noise you havent heard before? Unless it's been doing it for some time then you may be able to shorten the tensioner spring that runs around it's perifery. I will try and find a link to show the procedure unless someone else manages it sooner.
Here you go :- http://www.mad-ducati.com/Technical/Sta ... lutch.html
