It is currently Sun Feb 28, 2021 6:30 pm
 Post subject: Timing shaft
PostPosted: Sat Aug 04, 2012 7:49 am
Does anyone know if a later model timing lay shaft will fit the 904 engine? I need to replace one and I have been offered a cheap shaft from a 749/999 but I'm not sure if it will fit.
 Post subject: Re: Timing shaft
PostPosted: Sat Aug 04, 2012 8:05 am
:) I guess if its cheap you could just buy the thing and if it doesn't fit you could just tell everyone its the start of a 999 project ( watch this space :lol: :lol: :lol: )
PostPosted: Sat Aug 04, 2012 9:30 am
Thanks Mctool, you're vast knowledge and advice is, as always, very helpful. :fart: :lol:
PostPosted: Sat Aug 04, 2012 10:51 am
I don`t know either but the one of the 906/907ie is #14710011A which is the same on:
851/888/748/916.
The later timing shaft is 14710141A and is used on:
S4 2002
S4R 2004 - 2006
S4RS 2006
ST2 2000 - 2003
ST4 2000 - 2003
ST4S 2002 - 2005
ST4S ABS 2003 - 2005
ST3 2004 - 2005
ST3S ABS 2007
748 1999 - 2002
748S 2000 - 2002
748R 2000 - 2002
996 1999 - 2001
996S 1999 - 2001
996SPS 1999 - 2000
996R 2001
998 2002
998S Bostrom-Bayliss 2002
998R 2002
998 Matrix 2004
998S FE 2004
749 2003 - 2006
749S 2003 - 2006
749R 2004 - 2005
999 2003 - 2006
999S 2003 - 2006
999S AMA 2007
999R 2004 - 2005
As the 748 is listed for both my guess is the first is the one from 94-98.
PostPosted: Sat Aug 04, 2012 11:05 am
The models listed for the later shaft have a different crankcase with the 3-phase alternator. I would reckon it won't fit.
PostPosted: Sun Aug 05, 2012 10:58 am
Thanks G, Derek & McTool. :beer:
PostPosted: Wed Aug 08, 2012 11:16 pm
When trying to find what part might fit whatever , Sometimes it worth a look on flea bay to see if anyone has listed one with pix , a quick look might be all you need to know if it will fit or not :)
