Generator/Alternator for 906
Hi.
hope somebody can help me. My rotor has exploded and i'm therefore looking for a new generator. The one i have now is 3 phased but i can't quite find a new one. Anyone know where to but this ?
I have tried : ELECTREX WORLD, but the only have it in a 2 phase version. The regulator they have is 3 phased to it should be right we 3 phases..
Hope somebody can help.
Regards Thomas T
Regards Thomas T
Re: Generator/Alternator for 906
why is it noone new to the forum adds his location to the profile ?
You don`t have a 3 phase alternator if it`s still the original one.
Profile updated : Denmark...
It is mounted with a 3 phase alternator. I talked to : http://electrexworld.co.uk/ , and they said that the regulator for this model was a 3 phase model so it would suggest that the alternator also was a 3 phase.
Don't know what is right and what is wrong, but if i change to a 2 phase i would also have to change the regulator and
Regards. Thomas T
Regards. Thomas T
a three phase alternator has 3 yellow wires. Do you have that ?
Original are two yellow, one red. (in which case the Electrex G92 should be the right one)
It is possible to fit a 3 phase on a Paso but it is a very big deal as all the rotating parts are completely different including the crank.
- Derek
- year: 1994
He'd also need an alternator cover and possibly the crankcases as major changes were made to the engines when they moved to 3-phase.higgy wrote:It is possible to fit a 3 phase on a Paso but it is a very big deal as all the rotating parts are completely different including the crank.
crank cases are different but should not matter, covers are also part of the problem
This size and everything is exactly the same. Found one on ebay...
http://cgi.ebay.de/ws/eBayISAPI.dll?Vie ... OC:DE:1123
That fits a 906
That fits a 906
3 wires not 3 phase
I'm
Can you help me a bit here... ? Just so i understand..
Regards Thomas
Regards Thomas
Thomas,
there`s currenty a discussion ongoing in the P750 forum
http://forums.ducatipaso.org/viewtopic.php?f=1&t=6158
this is from the Electrosport website
http://www.electrosport.com/technical-r ... le-stators
And these graphics show the output of a single phase generator
vs. a three phase alternator
I understand this but as i read your answer i have a 2 phase alternator with 3 wires ? or ?
what is the last wire for ?
you didn`t read the post in the 750 forum
I have 906 alternators in stock for $100+shipping.
Ed Milich
Ducpower.com
Ducpower.com
