Hi have just bought a new/used clock and before replace the old one I would like to check if it is working....
how I can connect it to the battery? + and -
I have read the clock faq but still not understand how to reduce the risk of fault clock after long sleep.
If I check the battery level before try to start the engine I can solve the problem? If i have understood the clock blow if engine start with low battery level? I have just blowed mine....
ciao
how to check if clock it's working ;-)
Ducati Paso 906 grey 1990
Bmw K100rs 4v rot metallic 1992
Aprilia Tuareg Rally 1986
