It is currently Wed Jan 23, 2019 2:09 pm
 Post subject: Rear brake pump
PostPosted: Sat May 05, 2018 2:26 pm
Hi, can you tell me which rear brake pump would fit the 906 Paso?
I wanted to rebuild only the piston, but I have not got anywhere in the EU, I will probably have to replace the whole brake pump
 Post subject: Re: Rear brake pump
PostPosted: Sun May 06, 2018 8:31 am
Brembo seals and repair kits can be bought from KTM dealerships. Make sure that the model has the same master cylinder.
https://www.motorcyclespareparts.eu/en/ktm-parts/1994-620-duke-37kw-94-europe-motorcycles/rear-brake-control-duke-94
1982 Pantah 500SL
PostPosted: Wed May 09, 2018 2:08 pm
my piston is 11mm and they do not have a supply
PostPosted: Fri May 11, 2018 10:59 am
you can still find the complete pump.
https://www.stein-dinse.biz/Brembo/Fuss ... rettyPhoto
PostPosted: Tue May 15, 2018 1:48 pm
it will be it, thank you :thumbup:
PostPosted: Wed May 30, 2018 10:53 am
For information. Repair kits for the Brembo PS11 rear master cylinder (and many more) are available from Gutsibits in the UK.
https://www.gutsibits.co.uk/pr/TheShop/index.php?q=master%20cylinder&f=d&Model=0&search=SEARCH&spPage=4#topbar
1982 Pantah 500SL
PostPosted: Tue Jun 05, 2018 12:52 pm
I ordered here, thank you for the tip
https://www.stein-dinse.biz/Ducati/Brem ... 16254.html
I have a mounted brake and it works as it should :)
