It is currently Fri Mar 22, 2019 10:12 am
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
 Post subject: Re: Cold start
PostPosted: Tue Nov 14, 2017 9:33 am
Mc tool wrote:
Try ebay. I have found that Kiwi parts people are as helpful as hell if all they have to do is find a part # but ask them for an oil pressure sender 10x1mm tapered thread , 7lb's cracking , 6.3mm spade terminal, and they look at you like your mad. It can be #uckin frustrating knowing the dumb arses probly have the part but are just to stupid to know it. I sometimes use ebay as a source of info , often you can get the correct part no or description and what else it fits ,and the pix can help too as you can often read the writing on the part in the pic .
https://www.ebay.com/itm/Fiat-Punto-Coo ... Tn&vxp=mtr
This may be the right one :)
Nearly Hamish but that one's got the wrong connector.
This is the one you want :
https://www.ebay.com/itm/33065-temperature-sensor-ALFA-ROMEO-145-146-33-FIAT-PUNTO-60576529-46449499/152051441643?epid=1540430276&hash=item2366f8dfeb:g:YtcAAOSw0QFXDOf8&vxp=mtr
And here are the equivalents with part nos : http://www.endless-horizons.net/efi/wts.htm
And the datasheet : http://home.kpn.nl/duran103/pics/wts05%20v4.pdf
1982 Pantah 500SL
PostPosted: Fri Nov 17, 2017 8:22 am
Thanks for all your help on this, I've tracked the said item down and will let you know how things go when I have it installed.
Had some great riding today in the sunny Southern Hemisphere and the 907 kept up well with the more modern machinery, pretty impressive for something 26 years old
PostPosted: Fri Dec 01, 2017 8:45 am
Hi guys, really appreciate all the help, I replaced the temp sensor and bang, job done and is running perfect.
Cheers and best wishes for the Christmas season.
PostPosted: Fri Dec 01, 2017 10:17 am
Good to hear you've got it fixed :thumbup:
1982 Pantah 500SL
