748/916/996/998 Ft wheel, does the front fit a 907?
blazing928
Post by blazing928 »
I know that 851/900 17' rims fit, but do the later models, 748/916/996/998 fit a well?
This is only for the front rim of course
ta
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
ducinthebay
Re: 748/916/996/998 Ft wheel, does the front fit a 907?
Post by ducinthebay »
Everything will fit, except the 20 or 25mm ID bearings. You'll need to make a new spacer between the bearings if you swap them out.
