Page 2 of 2
Re: Oil level in 907 M1R forks ?
Posted: Thu Jun 11, 2020 7:30 pm
by angelix
my 906, 907ie and M1R all state 180mm
When I did my forks is what I put with a SAW 10W oil and I am quite happy with it.
Posted: Fri Jun 12, 2020 7:25 am
by Derek
angelix wrote:my 906, 907ie and M1R all state 180mm
Be wary of different brands of fork oil. It isn't always what is says on the packet. I found this out the hard way when I fitted an Andreani fully adjustable conversion to my Scrambler and I was wondering why the forks were hard as feck.
There are huge the differences in viscosity measured as Centistokes @ 40ºC between different makes of oil all allegedly the same SAE weight.
I can't upload the file with this info as a PDF and as images they are too large, at 800 pixels high they would be unreadable. I'll have to think of another way.
Posted: Fri Jun 12, 2020 7:35 am
Derek, email it to me.
Posted: Fri Jun 12, 2020 12:09 pm
by Derek
No need Gerhard. I've found the same info on an Australian website :
https://transmoto.com.au/comparative-oil-weights-table/
I should have used Öhlins 1309-31 but found it very difficult to find so I used Silkolene PRO RSF 5wt thinking it was a similar weight. It turns out that the Öhlins has a viscosity of 19 cSt @ 40ºC whereas the Silkolene is a whopping 26.7 cSt.
There are similar discrepancies across many manufacturers products.
