Speedbleeder
Speedbleeder
Hi.
While flicking through another Forum, I found a link to a crowd called Speedbleeder, Web address:
http://www.speedbleeder.com/
After spending an eternity getting the brakes bled after replacing the seals last year, these bleed valves look the goods. They also do a bleed valve for the clutch, which must be a good thing too. Has anyone found these bleed valves before and fitted them? They seem a pretty simple design and comparable in price to normal valves, it makes you wonder a bit?
Cheers.
Nick.
Cheers.
Nick.
Re: Speedbleeder
They sure look nifty , but you'd have a job convincing me that they will help bleeding "difficult " brakes or clutches . That ball valve only negates the opening and shutting of the bleed nipple as you bleed , I guess it would free up one hand to tear your hair out while its still not bleeding easily . A nice wee speck of bling all the same
Re: Speedbleeder
What hair? That went years ago....Mc tool wrote:They sure look nifty , but you'd have a job convincing me that they will help bleeding "difficult " brakes or clutches . That ball valve only negates the opening and shutting of the bleed nipple as you bleed , I guess it would free up one hand to tear your hair out while its still not bleeding easily . A nice wee speck of bling all the same
Cheers.
Nick.
Re: Speedbleeder
Well Nick , you know what they say ... " Moss doesn't grow on a busy stone " , and anyhow I have to pay to get mine cut off ..... gotta be a good thing
- ducinthebay
Re: Speedbleeder
Hmm, cheap enough to try.
- englishstiv
Re: Speedbleeder
No front brake bleed nipples for 907ie shown ???
DUCATI 907ie 1992
Re: Speedbleeder
yours are either M10x1 or M8x1.25
Re: Speedbleeder
Pretty sure the Goldline brakes are M10*1. Same as the back brake.
P750 are further down the list too.
Waiting for an Email from them. Will give them a crack and see how they go.
Cheers.
Nick.
Cheers.
Nick.
- persempre907
Re: Speedbleeder
Right point of view.ducinthebay wrote:Hmm, cheap enough to try.
However, does someone has tried it?
- ducinthebay
Re: Speedbleeder
I ordered some last night. I'll put them on the Sport and the ST, and let you know how they do.
Phil
Phil
Re: Speedbleeder
keep them covered and clean
- ducinthebay
Re: Speedbleeder
purchased extra boots too.
Re: Speedbleeder
What ... the haircut or the bleed nippleducinthebay wrote:Hmm, cheap enough to try.
