907i.e. tach problems
docbob
Post by docbob »
My tach suddenly stopped working. Occasionally dribbles up to 1000 rpm at best. Does anyone know any simple diagnostics for one of these? if it's kaput, I'm looking for one--will an earlier 906 or 750 Paso tach work?
Thanks,
Bob
ducinthebay
Re: 907i.e. tach problems
Post by ducinthebay »
Start with the cable. Like the speedo, its a spinning cable inside housing. If they get a bit dry, they will seize up and twist off. There is a ferrel on the top side to help support the inner cable and be a bearing. Like the speedo cable and speedo drive, they are often neglected an need some lube from time to time.
I just put one on my bike and the inner cable was really dry. I used some motor oil on it.
h1a
Post by h1a »
Hi, had similar symptoms on mine, turned out the gears in the head was worn out, parts 13 in this pic:
