It is currently Thu Jan 17, 2019 3:31 pm
 Post subject: Switch Nut?
PostPosted: Sun Apr 23, 2017 3:39 pm
This is driving me crazy. I've managed to lose the thumb nut that retains the trip meter reset cable to the dash panel. Does anyone have a spare they could sell me or tell me where on the earth I can find one? I believe it is a 14mm x 1mm. It is the switch nut that is low profile and generally tightened by fingers only so it is knurled not hex shaped.
Help!
RMR
1992 907ie
2001 900SS
2016 Scrambler Custom Icon
2011 Mustang GT
 Post subject: Re: Switch Nut?
PostPosted: Sun Apr 23, 2017 9:28 pm
Go to an auto electric shop and check out the switches , probly have to buy the whole thing but more than likely there will be something to fit. ..... Boat shop , car / bike wreaker ?? :)
PostPosted: Mon Apr 24, 2017 1:35 am
Thanks Mctool. I have tried looking into auto switches but so far nothing. A bike breaker is my next stop. Funny how these $.50 pieces can cause such frustration. I figured if it is just unobtainable, I'd have my machine shop make me one, for about $75!
RMR
1992 907ie
2001 900SS
2011 Mustang GT
PostPosted: Mon Apr 24, 2017 8:28 am
I measure 13mm inner diameter on mine (18,3mm od, 3,65mm thickness). So M14x1 as you said. I`ll have to pick up some parts for my car today or tomorrow. If I have a chance I`ll drop by the hardware store and see what they have.
For the forum search engine: trip resetter, trip counter, trip meter, lock ring, knurled ring nut
PostPosted: Mon Apr 24, 2017 3:41 pm
The hardware store doesn`t have anything like that.
If found them on the internet tho https://www.cncwarrior.com/product-p/22905.htm
In case you order one would you order one for me as well?
May be a good idea to ask how thick it is first. Imo up to 5mm would be ok.
Or http://www.ebay.com/itm/Select-M10-M27- ... XEGLwkSsKQ
PostPosted: Tue Apr 25, 2017 4:25 am
Okay cool. This is hugely helpful, thanks! BTW what's your tag? I have ordered a total of 4, I'm happy to send you 2 once they show up here and you let me know where to send them.
RMR
1992 907ie
2001 900SS
2011 Mustang GT
PostPosted: Tue Apr 25, 2017 3:29 pm
sent you a pm, thx!
PostPosted: Tue Apr 25, 2017 4:16 pm
That looks like the sort of thing found on a bicycle inner tube.
2004 ST4S
2001 ST4
1987 Paso 750
PostPosted: Wed Apr 26, 2017 2:13 am
Same idea but different size. Meant to be tightened by fingers only just like on a presta valve inner tube stem.
RMR
1992 907ie
2001 900SS
2011 Mustang GT
PostPosted: Sat Apr 29, 2017 6:15 pm
Hi RMR,
problem solved meanwhile?
machining one of would cost less than $ 75. I can make you one for way less.
if you're interested, please PM me.
regards, Bertus
