fuel pressure regulator best place to buy in UK
Hi all where would the best place be to get hold of a fuel pressure regulator for a 1992 907ie in the UK
Cheers re Alistair
Cheers re Alistair
Re: fuel pressure regulator best place to buy in UK
I don`t know but there`s a choice of aftermarket fuel pressure regulators (adjustable or not) you could adapt.
According to what was posted on this forum the fuel pressure is 3 bar. (I guess RP7 3,0 is stamped on the housing of the fpr)
PS: the Weber fuel pressure regulators of the Lancia Integrale is RP7 2,5. The one of the Sierra RS Cosworth is RP7 3,5 so they are not the correct ones.
Thanks for the replies just a question there is a small pipe routed from the regulator to the the intake what is its purpose, only aftermarket regulators I have seen haven't got this outlet and have only a supply and return. Thanks again re Alistair
from the wsm
- Unbenannt-1.jpg (146.14 KiB) Viewed 20627 times
rising rate fprs:
At times, in demand situations such as high acceleration, the engine needs more fuel. Rather than program a second set of fueling parameters to deal a special situation, one can take another route to the same place by using mechanics rather than ECU programming. In this case, these regulators are used. By having it react to engine vacuum (hose to the plenum), you can have it increase or decrease the fuel pressure on demand. In doing so, you are injecting more fuel though the injector duration remains the same.
- Fuel_Pressure_Regulator_09_11.png (40.43 KiB) Viewed 20621 times
- Derek
- year: 1994
Oddly, the connection to the manifold isn't used on any later injected Ducatis. It's just left open to the atmosphere.
a little bit offtopic but interesting:
https://app.box.com/s/dzhfmps8wql9yfblqdzwaphk8ppsk40c
what I found:
Bosch 0280160202
(It should be verified that the hose connections are the same to be sure this is not a dual outlet or whatever! So this is just a lead to pursue. Connectors are for 8mm fuel lines)
reference:
OPEL 815502
OPEL 8983638
OPEL 9281047
RENAULT 7700267390
VAUXHALL 8983638
found in:
OPEL Ascona 1900 E [A] (USA) 59-62KW/ 80-84PS 1.9l 02.1975 - 08.1975
OPEL Ascona 2.0 E 81KW/ 110PS 2.0l 08.1979 - 08.1981
OPEL Ascona 400 E 103-106KW/ 140-144PS 2.4l 08.1979 - 08.1981
OPEL Kadett 1.9 GT/E Coupe [C] 77KW/ 105PS 1.9l 09.1975 - 07.1977
OPEL Kadett 2.0 E Rallye-Coupe [C] 81KW/ 110PS 2.0l 08.1977 - 07.1979
OPEL Kadett 2.0 GT/E Coupe [C] 85KW/ 115PS 2.0l 08.1977 - 07.1979
OPEL Manta 1.9 E [A] (CDN,USA) 59-62KW/ 80-84PS 1.9l 02.1975 - 08.1975
OPEL Manta 1.9 i 77KW/ 105PS 1.9l 02.1977 - 07.1977
OPEL Manta 1.9 i 77KW/ 105PS 1.9l 09.1975 - 01.1977
OPEL Manta 2.0 i 77-81KW/ 105-110PS 2.0l 12.1981 - 06.1988
OPEL Manta 2.0 i 81KW/ 110PS 2.0l 08.1977 - 08.1981
OPEL Manta GT/E [A] 77KW/ 105PS 1.9l 02.1974 - 08.1975
OPEL Monza 3.0 i [A] (CH,S) 132KW/ 180PS 3.0l 01.1983 - 08.1986
OPEL Monza 3.0 i [A] 115KW/ 156PS 3.0l 09.1985 - 08.1986
OPEL Monza 3.0 i [A] 132KW/ 180PS 3.0l 01.1983 - 08.1986
OPEL Monza 3.0 i [A] 132KW/ 180PS 3.0l 02.1978 - 12.1982
OPEL Omega 3.0 i [A] 115KW/ 156PS 3.0l 03.1987 - 12.1987
OPEL Omega 3.0 i [A] 130KW/ 177PS 3.0l 03.1987 - 12.1989
OPEL Rekord 2.0 i [E] 81KW/ 110PS 2.0l 09.1977 - 08.1981
OPEL Rekord 2.0 i [E] 81KW/ 110PS 2.0l 11.1982 - 10.1984
OPEL Rekord 2.0 i [E] 81KW/ 110PS 2.0l 12.1981 - 10.1982
OPEL Senator 3.0 i [A] (CH,S) 132KW/ 180PS 3.0l 01.1983 - 08.1987
OPEL Senator 3.0 i [A] (ZA) 132KW/ 180PS 3.0l 01.1983 - 08.1987
OPEL Senator 3.0 i [A] (ZA) 132KW/ 180PS 3.0l 02.1978 - 12.1982
OPEL Senator 3.0 i [A] 115KW/ 156PS 3.0l 09.1985 - 08.1987
OPEL Senator 3.0 i 115KW/ 156PS 3.0l 09.1987 - 09.1993
OPEL Senator 3.0 i 130KW/ 177PS 3.0l 01.1988 - 12.1989
RENAULT 25 2.5i Turbo 133KW/ 181PS 2.5l 10.1984 - 05.1990
RENAULT Alpine 2.5i Turbo 147KW/ 200PS 2.5l 03.1985 - 06.1987
ROVER 3500 3.5
VAUXHALL Carlton 3.0 i 115KW/ 156PS 3.0l 03.1987 - 12.1987
VAUXHALL Carlton 3.0 i 130KW/ 177PS 3.0l 03.1987 - 10.1994
VAUXHALL Royale 3.0 i 132KW/ 180PS 3.0l 10.1978 - 12.1982
http://www.bowerspartsonline.co.uk/bosc ... 0280160202
Bosch 0280160202
reference:
OPEL 815502
OPEL 8983638
OPEL 9281047
RENAULT 7700267390
VAUXHALL 8983638
found in:
ROVER 3500 3.5
- 2498_0280160202%20(2).jpg (27.66 KiB) Viewed 20605 times
- 2498_0280160202%20(4).jpg (29.53 KiB) Viewed 20605 times
another option may be the fpr of a Volvo 850/S70/V70 which is 3bar as well.
This would require the housing, too.
I`m sure there are many others that could be used/adapted.
Of course the original part is still available but it has its price.
- $_57.jpg (85.79 KiB) Viewed 20605 times
- FuelPressureRegulator.jpg (67.27 KiB) Viewed 20605 times
why didn`t anyone point out that the picture in the wsm actually shows the wrong kind of fpr? It shows one with an IN, RETURN and OUT (+ vacuum) hence a fpr that would be positioned before the injectors.
I was looking at the parts catalogue of a 900SSie and noticed the fpr was actually behind the injectors hence has only an IN and RETURN (+ vacuum) and that it is the same on the 907ie.
It is 3 bar as well. So it would be a suitable option. The fpr sits in a housing (830.1.091.2A - http://www.desmoduck.com/search.php?par ... 0.1.091.2A) other than i.e. on the ST2 where it`s in the whole tank assembly where the fuel pump and filter is.
http://www.competitionsystems.co.uk/product.php?id=80
http://www.competitionsystems.co.uk/product.php?id=79
or cheaper
http://atspeedracing.co.uk/products/ind ... cts_id=360
The last two posts are still an option I think but one would have to reroute the fuel hoses a bit and block the exit of the second injector so that would only be a last resort solution.
or cheaper
- Unbenannt-1.jpg (60.6 KiB) Viewed 20561 times
Thanks for all info I haven't had time to do anything with the bike yet, but I also found that the fpr off a sierra rs cosworth from the 1980s looks a fit and there are aftermarket adjustable pressure ones available so i might investigate further, cheers all
if anyone in the US needs a spare one:
http://www.ebay.com/itm/400879122217?ru ... 26_rdc%3D1
