This is just one of several possibilities
Don't yet know if the Diode is blown but you can see the burned circuit from a little reckless troubleshooting one long night at the relays
Everything else works fine, now I have a test bed for ECU testing.Someday I might actually get around to fixin this one
No Fuel Pump
No Fuel Pump
Re: No Fuel Pump
Hi Higgy.
I have been reading your posts regarding talking to the P7 ECU and what have you. I have always been intrigued with the Jefferies MyECU http://www.myecu.biz/MyECU/index.htm
Had a look at the Web site last week again, and things look as if they have got a whole lot less expensive. Have you considered stumping for a kit and putting it together? I don't think it would be for the faint hearted, but the benefits could be interesting. It does appear to be everything the P7 isn't!
Cheers.
Nick.
Cheers.
Nick.
Re: No Fuel Pump
I looked into this a while back,he really didn't seem that interested in providing one for me
I think the Megasquirt would be a better option for me anyway but not quite ready to go there just yet if I can figure out how to turn on the comms for the P7 even if it means adding a daughter card to increase the memory
Guzzi's work utilizing the exact same ecu so it should be possible, just hard to find sources of info on such an old system
