lenses
allan macleod
lenses
Post by allan macleod »
looking for a source for a 1992 907ie left front signal lens
nickta
Re: lenses
Post by nickta »
Hi Allan.
I think the common answer to this "aren't we all!".
That to one side, I purchased a couple of mirror assemblies which came with the lenses, so will dig out the company name and put it up shortly. They may be able to help? They are the Farr mirrors, but the lenses look the same.
Welcome to the forum!
Cheers.
Nick.
nickta
Re: lenses
Post by nickta »
Hi Allan.
Give Henri at Moto-Science a crack. His web site is:
www.moto-science.com
Cheers.
Nick.
allan macleod
Re: lenses
nickta wrote:Hi Allan.
http://www.moto-science.com
Cheers.
Nick.
thanks for the tip
demidesmo
Re: lenses
Post by demidesmo »
I have a pair of lenses from a Cagiva Freccia ( looks familiar right? https://www.youtube.com/watch?v=VtvM6SETxXs ) that I bought as Paso lenses (from Australia)... but the size is slightly out by 5mm on the overall length and a little on the width. They look like they fit but... they don't fit.
I'm thinking that NOS Paso lenses are not a thing - so I need to do either;
3D scan the lenses and import them into 3D modelling software, for extensive tidying up (the inside texture is a diamond lattice nightmare plus how would I make sure the printing marks are removed?) and then scale them to fit the Paso's original pods.
or use these lenses to create a mould to mass-produce a large quantity and create a new indicator pod design (external aspects would almost identical) that can be 3d printed which uses the original metal clip-on bracket and possibly mirror lens assembly.
None of this is easy or straightforward which is why I have done nothing more than think about it.
I'm currently also on the lookout for a set of Cagiva Freccia 89-90 indicator pods to compare, but these are probably rarer than the Paso lenses.
randtcastell
Re: lenses
Post by randtcastell »
https://ducati-gowanloch.com/?s=paso
The lens are available and in stock @ Gowanloch Ducati! Have at it. I purchased one about a year back. Perfect. Worth every penny. Cheers. :^)
1987 Ducati P750
1973 Honda CB450
2022 KTM RC390
demidesmo
Re: lenses
Post by demidesmo »
well, thanks... saved me a bunch of hassle.
