ignition amplifier available?
Posted: Sat Aug 27, 2016 3:30 pm
by V12gte
Does anyone know where to get a replacement ignition amplifier? One of mine went bad. It is Ducati part 28740011a. It comes as a set of 2.
Does anyone have a spare, or is there an aftermarket mod? The initial search here only brought up a post about not destroying any ignition parts with a multimeter....
The bike started running on one cylinder, and the local guru says this is the culrprit.
It is not the same as the infamous voltage regulator, or is it?
Re: ignition amplifier available?
Posted: Sat Aug 27, 2016 3:47 pm
by V12gte
based on poking around and comparing how these look.....i might have answered my own question. Another vicitim of interchangeable terminology. If they are the same I know where the FAQ is and that roadstercycle.com has them....
Sigh.....
Posted: Sat Aug 27, 2016 10:35 pm
by higgy
Ed Miltch @ http://www.ducpower.com/ has a set now,not the same as the regulator
if I understand what you need
Posted: Sun Aug 28, 2016 4:10 pm
by V12gte
higgy wrote:Ed Miltch @ http://www.ducpower.com/ has a set now,not the same as the regulator
Thank you kindly for the lead.
Here is the pic of the part
Posted: Sun Aug 28, 2016 6:32 pm
if you google Marelli BKL 3B you find lots of info. Seems these parts were installed in sevral european cars and there are alternative modules.
A list is in these two auctions:
http://www.ebay.com/itm/HUCO-Ignition-C ... r#shpCntId
HUCO is HITACHI
http://www.motorpartsworld.com/parts/ignmaumpw188915
